Hello Guest it is June 09, 2026, 06:30:04 PM
Author Topic: Where to get 100 pin cable?  (Read 17695 times)
Offline A1CNC
  •  29 29
« on: October 10, 2009, 08:30:17 PM »
I have a 2140 and the icm 2900. Can anyone point me to where i can pick up a 100 pin cable?
Thank You,
Eric
Offline smurph
  •  1,575 1,575
Re: Where to get 100 pin cable?
« Reply #1 on: October 11, 2009, 12:14:26 AM »
100 pin cable: http://cyberresearchuniversity.net/store/cables-wiring/pc-computer-cables/scsi-cables/CBSCSI_10003_4229.2.htm
That's the 3ft. cable.  They also have 6 and 9 ft. cables.
Steve
Offline A1CNC
  •  29 29
« Reply #2 on: October 11, 2009, 08:13:27 AM »
Thank you Steve!
I will order that. Now I have to decide what machine to use the Galil on!
Eric
Offline A1CNC
  •  29 29
« Reply #3 on: October 13, 2009, 01:56:26 PM »
I have to compliment cyber research for their service, I ordered the cable yesterday and it showed up today!
Unfortunately, the cable has 2 male ends and the galil and Icm2900 seem to have the same gender connectors.
Any idea where to get the correct cable or maybe gender changers?
Eric
« Reply #4 on: October 22, 2009, 09:08:12 AM »
You are probably better off coughing up the $125 to buy from Galil.  Forget about the references to a "SCSI" cable.  SCSI uses several different connectors and was never 100 conductors.
The Galil uses the Tyco/AMP Champ 050 connectors.  This is basically a high density version of a Centronics type connector (remember the 36-pin printer cables?).  Male ends have flat connectors on both sides of a rectangular center piece.  I believe that the Cyber Research cable you ordered is a .050" Dsub cable, which uses pins and sockets (a HD version of the old serial port DB9 or DB25 connectors).
Board mount plugs and sockets are available for the Champ 050 system, but the cables or cable ends are almost impossible to find unless you want to order 6-800 pcs.
Mike
Offline A1CNC
  •  29 29
« Reply #5 on: October 22, 2009, 11:22:19 PM »
I have a friend who has a cable for me, I just have to wait for him to bring it back with him.
It will be a few weeks but the price is right. :)
Thanks for the replies.
Eric
