Hello Guest it is June 09, 2026, 04:18:23 AM
Author Topic: Pokeys, MPG, and MachTurn  (Read 28394 times)
Offline borisz
  •  220 220
    • www.poscope.com
Re: Pokeys, MPG, and MachTurn
« Reply #10 on: October 16, 2009, 12:58:39 AM »
Please upgrade PoKeys to latest version.
Do you have PoKeys connected to your computer directly without any USB hubs?
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #11 on: October 16, 2009, 02:43:18 AM »
OK, I will install it tomorrow.
Yep, its hooked directly to the motherboard.
-Jerry
« Reply #12 on: October 16, 2009, 07:57:05 AM »
hmmm,
    soundsl like you have noise on your MPG, try the MPG Tuning subsystem in M3
scott
« Reply #13 on: October 16, 2009, 01:52:01 PM »
Nope, no noise as far as I can tell. The pokeys encoder part of the app keeps track of the position of the encoder perfectly.
I did make a mistake in my description of the issue though. In single step it move one increment and stops. it wont move any further in that direction. In multistep mode it moves randomly.
« Reply #14 on: October 16, 2009, 02:25:24 PM »
It is not working like that on other systems.  It would be interesting to do these tests:
-   Doing the same setup on another PC with mach3 and nothing else configured.  There could be something creating a conflict.
-   Test your configuration files on a different PC (look for corrupted XML files).
Arturo Duncan
http://cnc4pc.com
« Reply #15 on: October 19, 2009, 01:13:01 AM »
Found the jitter problem. It was because of the development version of mach installed. Went back to the lockdown and all is good on that front.
The MPG still sucks though.
« Reply #16 on: October 20, 2009, 07:57:56 AM »
Understood,
     Boris is having his programmer add a "Tick Timer" to the pokeys, when that is done and a new version firmware comes out. I will update the plugin to use the Tick timer as well.
 Boris is also adding (at some point soon), a single Super fast MPG channel, still waiting on niews on that front.
Both will be added to the plugin as they become avail, I suspect that "Velocity" mode will have to have a Tick Timer available so Mach can calculate movement over time.
Scott
