February 13, 2012, 05:52:19 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  XBox360 Controller Plugin New User Info
Pages: « 1 2 3 4 5 6   Go Down
Print
Author Topic: XBox360 Controller Plugin New User Info  (Read 5692 times)
Leed3
Active Member
Offline Offline
View Profile
« Reply #50 on: June 24, 2010, 10:27:21 PM »
Hi Zafar
Thanks. I'll look at it soon.
Lee
atwooddon
Active Member
Offline Offline
View Profile
« Reply #51 on: July 31, 2010, 06:32:59 PM »
Lee, thank you for your efforts in developing the XBox pendant plugin.  I see many are using it successfully.
I 'liberated' my kids wired XBox controller (actually a MadCatz) when they got the wireless controllers and have downloaded and installed the XBox plugin in Mach3\Plugin as well as the drivers from Microsoft for the XBox controllers.  My system recognizes the controller, it is calibrated but when I start Mach3, I get an error saying 'Plugin DLL Defective. Reload' followed by 'XBox360Controller.dll - Defective Plugin Found..ingoreing.."   Mach3 then starts but there is no XBox plugin listed to configure.
My system is Windows XP Home Edition - SP3, Mach3 Ver R3.042.040
I have downloaded and reinstalled the XBox plugin, recalibrated the controller, etc, but no joy.  Any help you can provide will be appreciated.  I searched the forums about XBox controller but could not find a similar problem.
Thanks   Don
Leed3
Active Member
Offline Offline
View Profile
« Reply #52 on: July 31, 2010, 09:51:53 PM »
Hi Don,
You are welcome. What is the VendorId and ProductID?  They can be found in the Device Manager (control Panel - System).  Also make sure that you downloaded and installed the SDK mentioned on the Plugin page next to my plugin.
Lee
atwooddon
Active Member
Offline Offline
View Profile
« Reply #53 on: August 01, 2010, 12:16:12 PM »
I downloaded and updated the DirectX files/system and all works fine right now.  Thanks for the help.  I responded to this thread last night but I see my post did not make it to the thread.
Lee, once again thanks for your help.
Don
alpineboard
Active Member
Offline Offline
View Profile
« Reply #54 on: November 27, 2011, 09:29:36 AM »
Hi, I am trying to get the xbox360 plugin to work. The wireless controller I have is a sony sixaxis and is working (talking) with my pc using XP with a bluetooth dongle,  I am entering the vid and pid I got from device manager, then closing/open mach3 but it does not hold the values, it resets back to zeroes, and it does not dither the found/none controller option box, I did use Xpadder to get it temporary running but am concerned of safety. Is there something simple That I am missing here? As I would like to be able to use the plugin with all the options it has, Thank you, Robert
alpineboard
Active Member
Offline Offline
View Profile
« Reply #55 on: November 27, 2011, 10:43:29 AM »
Leed3
Active Member
Offline Offline
View Profile
« Reply #56 on: November 27, 2011, 11:47:34 AM »
Were you able to solve your problem?  The plugin works with those devices that use the Microsoft XInput header.  Many clone controllers use the same commands and structures as the Microsoft Controller.  That is why they work with the plugin.  I suspect that the Sony uses its own drivers based upon a different set of commands.  Therefore the plugin cannot see it.   Especially since it is for the playstation and not the XBox360.  I think you just need to get a different controller.
Lee
alpineboard
Active Member
Offline Offline
View Profile
« Reply #57 on: November 27, 2011, 10:05:38 PM »
Thanks for your prompt response, I think I will get a xbox360 controller, wired or wireless,  in time and extra$, if I get the wireless do you think my bluetooth dongle will talk with the xbox360 controller? reply when you can. thank you, Robert
Leed3
Active Member
Offline Offline
View Profile
« Reply #58 on: November 27, 2011, 10:46:52 PM »
If you get an "XBox360 Wireless Controller For Windows" it includes a USB transceiver.  They are about $40.00 on EBay.  If you only get the Wireless Controller then you will have to also buy the USB transceiver.  It does not work with a Bluetooth dongle.
Here is a link to the right one
http://www.ebay.com/itm/XBox-360-Wireless-Controller-Windows-Original-Pack-/320691218375?pt=AU_Video_Game_Accessories&hash=item4aaaafa7c7
Notice the small white rectanglular item above the controller.
Lee
Pages: « 1 2 3 4 5 6   Go Up
Print
Jump to:
