Hello Guest it is June 09, 2026, 09:33:08 PM
Author Topic: for using 'CustomMacro1~10'  (Read 9266 times)
« on: September 29, 2009, 07:34:09 PM »
Hello everyone!
Please teach the method of using'CustomMacro1~10'.
What kind of number should be written on the 'CustomMacro1'BOX of Dialog on config shuttle.
« Last Edit: September 29, 2009, 07:51:08 PM by Maniac »
Re: for using 'CustomMacro1~10'
« Reply #1 on: September 29, 2009, 08:49:29 PM »
You write a VB macro, as a custom M-code.   You do this by creating a file Mnnn.m1s in the Mach3\macros\Mach3Mill directory. nnn is the M-code number.  So, if you create M123.m1s, then you can put an "M123" in your G-code, and that macro will execute.  To use that same macro as a Custom Macro in the ShuttlePro, just put the number, 123 in this case, in the configuration dialog.
« Reply #2 on: September 30, 2009, 01:32:42 AM »
Thank you for a prompt explanation.
Was it M code number?
I will try it.
« Reply #3 on: September 30, 2009, 02:36:18 AM »
Hi !  Ray L.
It went well. Thank you.
