Hello
Guest
it is
June 09, 2026, 12:00:21 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach Screens
Machscreen Screen Designer
(Moderator:
Klaus1311
edit offset screen or other screen
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: edit offset screen or other screen (Read 13240 times)
tantan
130
on:
September 21, 2009, 01:41:52 PM »
hi,
if i want to edit the offset, toolpath or MDI screen, how can i select that specific screen.
thanks
antoine
Klaus1311
531
Re: edit offset screen or other screen
Reply #1 on:
September 22, 2009, 09:50:31 AM »
Hey Antoine,
when you've loaded the screen set, in the upper left part of the property dialog you can select the page.
Klaus
The brain isn't a soap, it doesn't shrink when used.
tantan
130
Reply #2 on:
September 22, 2009, 10:32:54 AM »
hi,
thanks. it works.
with kind regards.
Antoine
Print
Pages:
1
Go Up
« previous
next »
