May 25, 2012, 08:09:14 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  Latest PoKeys Plugin version!!!
Pages: 1   Go Down
Print
Author Topic: Latest PoKeys Plugin version!!!  (Read 1005 times)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« on: September 15, 2009, 07:21:39 PM »
UPDATE/UPGRADE:
NOTE!!!!!:  You MUST have you Pokeys Firmware upgraded to at least version 2.0.5 to be able to use the 32 bit encoders.
    Version 4.12, this one supports 32 bit Encoders now (and they are FAST!!!). You have all 7, but I added "Encoder Mapping"
for your convienance on the PoKeys Cfg page of the plugin dialog.
For instance you set up "Encoder1" in pokeys software, but you want to map that encoder to MPG1 (which is encoder [4] in mach tecnicallly). On the Cfg dialog
page you will see the check box to "User Encoder1 from PoKeys" and a edit box to the right of that, you would put in this case the # 4 in that box. The number 4
represents the MPG1 in Mach3. (Note: you would still need to set up the Port10, and A and B pins to match the Encoder1 A and B pins on your Pokeys in machs Ports and Pins->Encoders/MPGs.
Note if your using Multiple encoders in the pokeys and are mapping them to encoders/mpgs in mach 3, then each encoder has to go to its own UNIQUE map. In other words, you can't send encoders1 and 2 from pokeys BOTH mapped to "4" (MPG1), it NO-Worky.
A slight timeout was added to the LCD write, so that it has time to refreash and stabilize, so you don't have "flicker" especially noticeable on larger LCDs (4x20 for example).
WARNING!!!!!:  This installs a  "Blank"  PoKeys/XML meaing that you had better write down your OLD settings for pins and Uleds/Dros etc. prior to installing this one!!
This one when you go to the "PoKeys Cfg.." dialog will come up with Everything turned OFF, and "default" values on some of the boxes.
Remember set up your PoKeys the way you want it, with the PoKeys soft ware (i.e. pick your encoders and thier pins) and write it to your PoKeys. Then start Mach3, and match your "PoKeys Cfg.." to your choices with the PoKeys.  NOTE: Mach uses TRUE indexing on the Digital IO, meaning PoKeys labels pin 1, as Pin1, but mach calls Pin1, 0.  So in mach3 PoKeys Cfg, Pin 0 = pokeys pin1, Pin 1 = pokeys pin2, etc.
also remember on the digital IO, the inputs have to be in a continous range, and the outputs have to be in a continous range, no skips in the range. Since Pin 13 of Pokeys doesnt work, you could do 4 digital inputs, and 4 digital outputs like (on the pokeys inputs Pin 9-12, in mach that would be 8-11, skip Pokeys pin 13, then pokeys outputs Pn 14-17, in mach would be Pins 13-16).
Attached is the "LCDPokeys32Enc4-12.zip" unzip it to your desktop. NOTE: READ the readme file that is in the zip!!
Also:  If you have already installed previous versions of the MSI installed PoKeys, you will need to uninstall it first before you can install this one.
Link is here, Reply #2:
http://www.machsupport.com/forum/index.php/topic,12188.new.html#new
>>>>>>> EDIT >>>>>>>>>>>>
The above about the XML over write, is ONLY if you are running the Old "PoKeys.XML" profile from previous PoKeys MSI's installers from me.
if your running your own profile, then the only thing you would need to do is possibly "re-enable" you pokeys plugin, since the version numbers
on it change, it will disable it self on install.
If you runniing your own XML, but want to use the PoKeys.set just load it from the: "View->Load Screens" menu.
scott
« Last Edit: September 17, 2009, 09:25:08 AM by poppabear » Logged
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #1 on: November 02, 2009, 10:19:23 PM »
Update/Upgrade:
    PoKeys plugin version 7.5
You will need to uninstall any previous versions if you used the MSI installer in the past.
Added:
1). There is now 2 ranges of  Mapping pokeys inputs to user leds.
2). There is now 2 ranges of Mapping user leds to outputs pokeys.
3). There is 2 extra/optional PWM outputs, one for controlling LCD backlight LED brightness, and the other for controlling Text contrast.
4). Preconfigured Pendant controls, for the: 4 axis, and 6  axis pendants sold by, CNC4PC, and Boris of PoScope, also a option on a preconfigured PoPendant when Boris finally gets his "PoPendant" out.
Screen shot of PoKeys Config page.
Screen shot of LCD PWM control page.
here is the link (Reply #4):
http://www.machsupport.com/forum/index.php/topic,12188.msg85244.html#msg85244
Scott
Pages: 1   Go Up
Print
Jump to:
