Hello Guest it is June 12, 2026, 02:03:13 AM
Author Topic: FeedRate OverRidden  (Read 9977 times)
Offline kolias
  •  1,165 1,165
FeedRate OverRidden
« on: September 15, 2009, 10:23:37 AM »
Guess I will have to ask my question in a different way (asked in another thread and got no answers)
As per attached files, I set my lettering in LC to be engraved at 10”/min feed rate and when the program is saved for Mach, the feed rate is changed to 0.40”/min.
When I run the program in Mach the router stays in the same place and the stepper(s) hum (cant say if it’s one motor or all)
What is the problem?
Nicolas
Nicolas
  •  9,356 9,356
Re: FeedRate OverRidden
« Reply #1 on: September 15, 2009, 10:44:46 AM »
Hi Nick,
I changed all the 'F0.40' feedrate commands using 'EditCNC' to 'F400' and your .tap file runs OK.
« Reply #2 on: September 15, 2009, 10:45:39 AM »
Nicolas
I would guess your CAM program is working in mm, and Mach is working in inches.  10 mm/min = 0.397 in/min
Offline kolias
  •  1,165 1,165
« Reply #3 on: September 15, 2009, 11:30:31 AM »
Thanks Tweakie but I want to know why I get this problem so I can learn
I have in LC the same sample sign drawing which I divided in 3 layers. The 1st layer which was all the interior design worked like a charm. Then I hide the 1st and 3rd layers and unhide the 2nd layer which has 3 words and that is the one I have the problem. The 3rd layer which is the perimeter of the sign also worked like a charm.
Therefore to my opinion I don’t think that LC is working in mm as Ray suggests.
BTW how do you select in LC between inches / mm? So far what I’m doing is using the Scale from the tool bar, click on mm to inches, and set the size I want.
Thank you both
Nicolas
Nicolas
