May 25, 2012, 08:06:41 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  USB Plugin development
Pages: 1   Go Down
Print
Author Topic: USB Plugin development  (Read 3449 times)
Alberto
Holding
Offline Offline
View Profile
« on: September 03, 2006, 03:16:50 AM »
Hi all,
I nearly finished my plugin for an USB interface, but I have some questions that mybe you guys can help me.
I am using the Visual studio 2005 complier and compiled the blankmovement project. All right. Here is the pb: the Time var in the GMove structure is always zero in the SendHoldingMovement(), despite of the movements or jogging in step mode or whatever. I am intent to use the differencial data direvative move, so the Time var is essential. Anyone went into this pb ? I can't understand if it's due to the new compiler or there is something else...where is the catch ? any idea or suggestion ?
Thanks in advance. Wink
Brian Barker
Administrator
Offline Offline
View Profile
« Reply #1 on: September 03, 2006, 06:14:58 AM »
You are the first one that has got 2005 to work Smiley Art and I run 2003...
If you can get 2003 it should work fine..
Fixing problems one post at a time Wink
www.newfangledsolutions.com
www.machsupport.com
Pages: 1   Go Up
Print
Jump to:
