May 25, 2012, 07:59:16 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach3 under Vista
| | |-+  Ver. 3 full screen
Pages: 1   Go Down
Print
Author Topic: Ver. 3 full screen  (Read 1218 times)
mwb
Active Member
Offline Offline
View Profile
« on: September 10, 2009, 01:51:08 PM »
The latest version of Mach3 running on Vista will not display full screen.  I've tried on an XP platform and it
displays it fine.  Anyone else experience this ?
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: September 10, 2009, 03:39:25 PM »
It has nothing to do with Vista, it has to do with the display resolution, graphics driver, font settings, etc. There is also a 'Screen Control' section in Config->General config (lower right corner) that may help.
Happy machining , Jeff Birt
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: September 10, 2009, 04:28:49 PM »
Do you have Auto Screen Enlarge checked in General Config?
mwb
Active Member
Offline Offline
View Profile
« Reply #3 on: September 11, 2009, 09:23:20 AM »
Thanks all!  The high res did the trick.  Thanks
Mark
Jeff_Birt
Active Member
Offline Offline
View Profile WWW
« Reply #4 on: September 11, 2009, 09:25:05 AM »
Glad you got it sorted!
Pages: 1   Go Up
Print
Jump to:
