Hello Guest it is June 12, 2026, 08:15:55 AM
Author Topic: LAZYCAM - DEFINITON OF ANY TERM IN THE MANUAL  (Read 250231 times)
Re: LAZYCAM - DEFINITON OF ANY TERM IN THE MANUAL
« Reply #10 on: June 12, 2011, 07:30:27 PM »
Post the dxf file. I never had that problem and have backplotted enough of the code to know that the dimensions
are not changed.....but you never know.
« Reply #11 on: July 30, 2011, 04:43:35 PM »
Is there a free drawing software that mach3/lazycam can use?
Offline kolias
  •  1,165 1,165
« Reply #12 on: July 30, 2011, 05:19:47 PM »
I use Inkscape.org, a pretty good software
Nicolas
« Reply #13 on: November 10, 2013, 09:56:54 AM »
hi,guys
I'm too new in your huge word. and I need for your support please .
I was trying to practicate tutorial#5 of LAZYCAM manual, but I failed to do it at the step of posting the G code to MACH3 .
I was following the manual step by step (all OK) until the step  "post code" there is no file to be saved ?????? nothig was posted I checked the destination file --->empty. also there was no confirmation that the code was created.
does it have a relation to licence or what?
« Reply #14 on: November 10, 2013, 06:01:41 PM »
MOHEMEDHELMI,
The lathe module requires a license in order to use it.
I strongly suggest you skip LazyCam for the lathe and use LazyTurn instead as that was done to replace
Lazycam's Lathe module.
