Hello Guest it is June 09, 2026, 07:04:22 AM
Author Topic: The Laser Project.  (Read 2966861 times)
0 Members and 58 Guests are viewing this topic.
  •  9,356 9,356
Re: The Laser Project.
« Reply #40 on: October 10, 2009, 03:59:10 AM »
These are my first thoughts on the control circuit for the laser tube.
May be changed a bit after I have thought it through but looks good for now.
Update; Diagram updated.
« Last Edit: November 15, 2009, 02:28:02 AM by Tweakie.CNC »
  •  9,356 9,356
« Reply #41 on: October 12, 2009, 02:02:06 AM »
Pretty basic stuff but this is the proposed cooling circuit.
« Last Edit: November 04, 2009, 03:18:27 AM by Tweakie.CNC »
  •  9,356 9,356
« Reply #42 on: October 14, 2009, 01:33:01 AM »
Another piece in the grand jigsaw puzzle has arrived from the USA. This is the Gems Sensors flowswitch - it has 1/4 NPT threads and I have made hose connections from stainless and phonelic which can be attached with pipe fittings.
  •  9,356 9,356
« Reply #43 on: October 17, 2009, 08:14:28 AM »
Started getting the parts fitted to the machine. Radiator, circulating pump and flowswitch are in place. Still waiting for the header tank and fan guards but this will not hold up the wiring etc.
  •  9,356 9,356
« Reply #44 on: October 19, 2009, 10:14:19 AM »
Now that the beam steering fixture, mirror positions and adjustments have all been carried out using the HeNe laser it is now time to fit the CO2 tube onto it's mountings and connect the wiring and pipework. I have also fitted a small, digital milliamp meter (to the front of the laser enclosure) which will display laser current during use.
« Last Edit: October 19, 2009, 11:41:06 AM by Tweakie.CNC »
  •  9,356 9,356
« Reply #45 on: October 21, 2009, 09:20:01 AM »
Just engraved some of the obligatory labels that have to be fitted to the laser housing.
« Reply #46 on: October 21, 2009, 12:30:06 PM »
Looking very good  :)
It's a hefty cooling system you have installed.
« Reply #47 on: October 21, 2009, 09:15:44 PM »
Yup, that Tweakie is first class all the way.
  •  9,356 9,356
« Reply #48 on: October 22, 2009, 01:35:41 AM »
Thanks Guys.
I keep wondering if the cooling system will be man enough for the job.  ;D
« Reply #49 on: October 22, 2009, 01:38:19 AM »
Thanks Guys.
Well, maybe one more fan to be sure it can handle the load ;)
