Hello
Guest
it is
June 09, 2026, 03:40:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
cant get reset button to turn off
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: cant get reset button to turn off (Read 9246 times)
alex850
29
on:
August 23, 2009, 09:45:10 AM »
I downladed the new nversion of mach last night. For some reason i cant get the reset button off so i can run my gcode,so i downloaded the older version still haveing problems with it. whats wrong with it?
thanks alex
Re: cant get reset button to turn off
Reply #1 on:
August 23, 2009, 09:53:15 AM »
Go into config>ports & pins>input signals and enable the ESTOP mine is just emulated.
alex850
29
Reply #2 on:
August 23, 2009, 10:45:12 AM »
checked on and off did not work either way?
alex
Carnoustie, Scotland
Reply #3 on:
August 23, 2009, 11:12:07 AM »
Look on the diagnostics page and see if any of the limit LEDs are active. If they are then check in Ports and Pins to see you have them set right. If you dont have limit switches then disable them in Ports and Pins. If you do have limits and they are set right then check that the actual switches are not activated or wiring come loose.
Failing that attach your xml and we can have a look to see if there is a problem with it.
Print
Pages:
1
Go Up
« previous
next »
