May 25, 2012, 06:50:57 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Machine coordinate by a VB fonction
Pages: 1   Go Down
Print
Author Topic: Machine coordinate by a VB fonction  (Read 1121 times)
Freddy Bastard
Active Member
Offline Offline
View Profile
« on: August 21, 2009, 10:19:19 AM »
Do we have a way to switch from Machine coordinate to Program Coordinate with a VB fonction?
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: August 21, 2009, 01:50:15 PM »
Yup,
Code "G53"
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Freddy Bastard
Active Member
Offline Offline
View Profile
« Reply #2 on: August 24, 2009, 10:13:27 AM »
Ok thank's
Here's another question... In a VB script, how can we know if the machine coords button is active? Some kind of protection.
ie: if machine coords is active, stop the routine and show a alarm.
Thank's
vmax549
Guest
« Reply #3 on: August 24, 2009, 10:21:10 AM »
(;-)  THere are 3-4 ways to switch to MACHINE coord depending on exactly what you need. There is also an LED that indicates when Mach is in machine coord mode.
They are listed in the cutomizing mach2 manual(;-)
Freddy Bastard
Active Member
Offline Offline
View Profile
« Reply #4 on: August 24, 2009, 10:26:25 AM »
I don't really want to switch to machine coordinates. I want a warning if I try to run a VB script (ie: z probing) and machine coordinates is active.
Fred
vmax549
Guest
« Reply #5 on: August 24, 2009, 03:38:11 PM »
" There is also an LED that indicates when Mach is in machine coord mode."
Freddy Bastard
Active Member
Offline Offline
View Profile
« Reply #6 on: August 25, 2009, 07:34:07 AM »
Dim Test as Boolean
Code "G80G90G50"
Thank's, here's my solution for my problem. I added this portion of code to all my probing macros...
Test = GetOEMLed(16)
If Test then
    Message "***DONT PROBE IN MACHINE COORDS"
    Exit Sub
Else
End if
Freddy Bastard
Active Member
Offline Offline
View Profile
« Reply #7 on: August 25, 2009, 07:43:03 AM »
oups sorry...
Dim Test as Boolean
Code "G80G90G50"
If Test then
    Exit Sub
Else
End if
Pages: 1   Go Up
Print
Jump to:
