Hello
Guest
it is
June 09, 2026, 04:28:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
Machine coordinate by a VB fonction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Machine coordinate by a VB fonction (Read 11197 times)
Freddy Bastard
5
on:
August 21, 2009, 10:19:19 AM »
Do we have a way to switch from
Machine coordinate
to
Program Coordinate
with a VB fonction?
Chaoticone
5,624
Precision Chaos
Re: Machine coordinate by a VB fonction
Reply #1 on:
August 21, 2009, 01:50:15 PM »
Yup,
Code "G53"
If you could see the things I have in my head, you would be laughing too.
Freddy Bastard
5
Reply #2 on:
August 24, 2009, 10:13:27 AM »
Ok thank's
Here's another question... In a VB script, how can we know if the machine coords button is active? Some kind of protection.
ie: if machine coords is active, stop the routine and show a alarm.
Thank's
vmax549
Reply #3 on:
August 24, 2009, 10:21:10 AM »
(;-) THere are 3-4 ways to switch to MACHINE coord depending on exactly what you need. There is also an LED that indicates when Mach is in machine coord mode.
They are listed in the cutomizing mach2 manual(;-)
Freddy Bastard
5
Reply #4 on:
August 24, 2009, 10:26:25 AM »
I don't really want to switch to machine coordinates. I want a warning if I try to run a VB script (ie: z probing) and machine coordinates is active.
Fred
vmax549
Reply #5 on:
August 24, 2009, 03:38:11 PM »
" There is also an LED that indicates when Mach is in machine coord mode."
Freddy Bastard
5
Reply #6 on:
August 25, 2009, 07:34:07 AM »
Dim Test as Boolean
Code "G80G90G50"
Thank's, here's my solution for my problem. I added this portion of code to all my probing macros...
Test = GetOEMLed(16)
If Test then
Message "***DONT PROBE IN MACHINE COORDS"
Exit Sub
Else
End if
Freddy Bastard
5
Reply #7 on:
August 25, 2009, 07:43:03 AM »
oups sorry...
Dim Test as Boolean
Code "G80G90G50"
If Test then
Exit Sub
Else
End if
Print
Pages:
1
Go Up
« previous
next »
