Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 25, 2012, 05:17:56 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
FAQs
My z plane isn't perfectly level
Pages:
1
Go Down
« previous
next »
Author
Topic: My z plane isn't perfectly level (Read 1282 times)
rdlohr
Active Member
Offline
on:
July 21, 2009, 07:19:35 AM »
If have a 14" x 14" cutting area and the Z plane not perfectly level . Its off by .04" worst case measured in the corners. This matters when cutting slots in Lexan that go most of the way through the Lexan. This extra 4/100" error sometimes allows too little material left under my slots. I'm considering shimming under my table mounts, but I wondered if Mach 3 allows me to program in this offset. I can't be the first person to have this problem.
Rick
Global Moderator
Online
Re: My z plane isn't perfectly level
Reply #1 on:
July 21, 2009, 08:33:24 AM »
Rick,
Can you post a pic of the machine?
I think fixing the machine would be better than a programing solution.
rdlohr
Active Member
Offline
Reply #2 on:
July 21, 2009, 08:40:00 AM »
Thanks. It's a K2CNC machine.
http://www.k2cnc.com/shop/proddetail.asp?prod=KT%2D1414%2D09&cat=26
I would have to remove the table top and put shims under it of various thicknesses at about 12 screw locations. While this is doable and not a big deal, it would be easier to pull up a screen that let me put in an offset for each of four corners. Actually, you would only need three assuming the fourth point would be at zero referenced to the other three.
Rick
Last Edit: July 21, 2009, 08:46:02 AM by rdlohr
Global Moderator
Online
Reply #3 on:
July 21, 2009, 12:07:31 PM »
Rick,
Fix the the bed and eliminate the problem or just mount a piece of your choice and machine / face the mounted piece.
ger21
Global Moderator
Offline
Reply #4 on:
July 21, 2009, 12:37:48 PM »
Typically you bolt a sacrificial bed in place, and machine it flat. That's what most router owners do.
http://home.comcast.net/~cncwoodworker/2010.html
rdlohr
Active Member
Offline
Reply #5 on:
July 21, 2009, 01:57:22 PM »
Thanks for the input. I had considered that. In my case, I'm milling Lexan and to produce a clean edge underneath, I have a 1/4" air gap under the Lexan I am machining. I had some melting problems when I had a sacrificial Lexan sheet underneath initially. I have a fixture that is held on all the edges that has a 14" X 14" cutout for the area that I do my cutting in. I guess I could do a different hold down scheme utilizing a sacrificial board underneath that has been milled.
I guess Mach 3 doesn't have an easy way to do this.
BluePinnacle
Active Member
Offline
Reply #6 on:
September 10, 2009, 09:50:23 AM »
a little late perhaps, but how about a metal plate table? it would tend to sink heat out of the plastic. Also, do you have any cooling arrangements in place? Compressed air jets to the tool may help, or water vapour, depending on your electrical arrangements and sealing.
rdlohr
Active Member
Offline
Reply #7 on:
September 10, 2009, 02:04:22 PM »
All cooling is done by a vacuum. Actually, when I had the heat problem I think it was prior to having a vacuum in place.
To solve my problem, I shimmed the table top underneath and now it is accurate to about .005 so it works great. Thanks for the inputs.
Rick
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
