Hello Guest it is June 12, 2026, 08:16:47 AM
Author Topic: ARC codes cause issues with program extremes calculations.  (Read 13005 times)
« on: July 09, 2009, 11:02:32 PM »
not a complaint. merely an observation.
my screen gives me a program run extreme synopsis as i load my gcode which lets me know how far either side of XYZA 0 my part will move,  great feature as i can quickly check what size wax to chop up for a job, but if i path with ARCS then these extremes can reach bizarre false limits and has made it impossible for me to setup softlimits since they are almost always overshot by this error.
as an example a small ring with x not going more than say  20mm either side of X0 may be read be program extremes as being from -X780 thru +X1980 if i path the flip cuts with arc outputs into the code.
perhaps this is a known issue and someone has allready solved it?
Re: ARC codes cause issues with program extremes calculations.
« Reply #1 on: July 10, 2009, 01:52:43 AM »
What version are you using, it was an issue a while back but I had thought it was  fixed in Mill. In Turn its still screwed up, maybe someday turn will get attention ;)
« Reply #2 on: July 10, 2009, 02:03:09 AM »
this one :)
« Reply #3 on: July 10, 2009, 07:13:01 AM »
It may not be connected but I had a problem using G41 with G91 and arcs were highly distorted.  Ger21 suggested to use Version 3.043, the development version and this fixed the problem.
« Reply #4 on: July 10, 2009, 11:40:33 AM »
Chris, let me know if you try the new version. It's bugging me also.
I also get some real odd looking lines in the toolpath display using arcs.
Ken
« Reply #5 on: July 10, 2009, 04:06:05 PM »
K Will download and test later today.
« Reply #6 on: July 10, 2009, 11:21:03 PM »
nope. same issue persists.
want me to upload some code tonight?
