May 24, 2012, 08:04:04 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Hotkey Keystrokes?
Pages: 1   Go Down
Print
Author Topic: Hotkey Keystrokes?  (Read 1179 times)
stringkilla
Active Member
Offline Offline
View Profile
« on: January 04, 2006, 09:07:12 PM »
I have another problem. I know I,m becoming a pest. I really need to know what keystroke's correspond to the number 33 and 34. These are the numbers in the hotkey boxes that control the Z axis jog. It seems in my panic I messed them up and now, I can't find them. I am in dire need. I need HELP.
chad
Global Moderator
Offline Offline
When the going gets weird, the weird turn pro.
View Profile
« Reply #1 on: January 04, 2006, 11:04:04 PM »
The default Mach install will be, page-up, and page-down.  33 z++ 34 Z- -
chad
stringkilla
Active Member
Offline Offline
View Profile
« Reply #2 on: January 05, 2006, 09:52:31 AM »
I guess I might ask this obvious question. Is that with the shift button??
stringkilla
Active Member
Offline Offline
View Profile
« Reply #3 on: January 06, 2006, 08:47:01 AM »
Yes, but what keystrokes will make that happen? I'd like to get them back, but in the mean time I've allocated the numbers 1 & 4 for Z+, Z-, respectively. In the end I need to KNOW WHAT KEYSTROKES MAKE THE NUMBERS 33 & 34 end up in those boxes
John S
Active Member
Offline Offline
Nottingham England
View Profile
« Reply #4 on: January 06, 2006, 09:48:45 AM »
High light the box needed like Z++ then whilst highlighted hit Page up and it will insert the number 33.
If the number 33 is alreday there then iy will use page up [ no shift]
Many of the questions you are asking are basic and you really do need to sitdown and read the manual.
It's a good manual and that's what it's there for.
John S.
stringkilla
Active Member
Offline Offline
View Profile
« Reply #5 on: January 07, 2006, 09:57:32 AM »
John, that did not work. The manual does not address this issue. I've contacted Art for some expert advice in this matter. I've read the manual, and it's true there are many things there I do not understand. I thought that's what this and other forums where for?
rolexmechanic
Active Member
Offline Offline
View Profile
« Reply #6 on: July 02, 2011, 12:07:49 PM »
http://designedplay.files.wordpress.com/2007/09/flash_keycodes.pdf
Pages: 1   Go Up
Print
Jump to:
