Hello Guest it is June 09, 2026, 09:51:54 AM
Author Topic: Smooth Stepper is GREAT, but for a couple of issues  (Read 13093 times)
« on: July 06, 2009, 04:41:51 PM »
I just got my SS hooked up and running today.  ;D
I must say, this thing is awesome! I'm running an old Dell dimension 3000 with 2.8mhz processor. I never could run Mach at more than 35k kernel at 1800mm/min velocity. I could jog fine at those speeds, but couldn't cut an actual part without the motors skipping, stuttering and generally be fussy.
I cut my first piece today at 3000mm/min without a hiccup.
I'll post a video tomorrow.
I am having just a couple of quirky issues though.
When I run my toolprobing script, it moves at an unbelievably SLOW pace. 90mm/min. My probe is located on the opposite side of my table from the home switches and it takes forever to get over there and down on the probe.
Also noticed sometimes my rotary table wont back off the switch when I home it.
Any ideas?  ???
Ken
Re: Smooth Stepper is GREAT, but for a couple of issues
« Reply #1 on: July 07, 2009, 10:03:10 AM »
Here is a vid of my mill in action with SS and Mach
http://www.youtube.com/watch?v=JaAjhnhsPfw
Ken
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #2 on: July 08, 2009, 08:37:23 AM »
Without seeing your probing script I don't think anyone will be able to help you. For you limit switch issue you may need to adjust the filtering in the SS config.
Happy machining , Jeff Birt
« Reply #3 on: July 08, 2009, 09:33:54 AM »
Thanks for the reply Jeff. Here is my probing script.
Sub Main()
'probe
HomSigX = IsActive(2)
HomSigY = IsActive(5)
HomSigZ = IsActive(8)
Xreferd = GetLED(7)
Yreferd = GetLED(8)
Zreferd = GetLED(9)
If HomSigX Or HomSigY Or HomSigZ = True Then
        MsgBox("Home switch active...please deactivate before tool change.")
        Exit Sub
End If
If Xreferd Or Yreferd Or Zreferd = True Then
        MsgBox("Axis not referenced...please home all first.")
        Exit Sub
End If
LastFeed=GetOEMDRO(818)
SetUserLED(1001,False)
SoftState = GetOEMLED(815)
If SoftState = True Then
DoOEMButton (119)
SetUserLED(1001,1)
End If
SetUserLED(1002,0)
WorkUnits = GetOEMLED(801)
If WorkUnits = True Then
code "G21"
SetUserLED(1002,1)
End If
DoOEMButton(104)
While IsMoving()
Sleep 100
Wend
xTSensPos = GetUserDRO(1200)
yTSensPos = GetUserDRO(1201)
code "G00"
code "G53X" & xTSensPos & "Y" & yTSensPos
While IsMoving()
Sleep 100
Wend
SensGapPos = GetUserDRO(1203)
code "G00"
code "G53Z" & SensGapPos
While IsMoving()
Sleep 100
Wend
zTSensPos = GetUserDRO(1202)
SensSpeed = GetUserDRO(1204)
code "G31Z" & zTSensPos & "F" & SensSpeed
While IsMoving()
Sleep 100
Wend
CurrFixture=GetOEMDRO(46)
Select Case CurrFixture
Case 2
     ProgXZero = GetUserDRO(1209)
     ProgYZero = GetUserDRO(1210)
     ZtoProbe = GetUserDRO(1212)
Case 3
     ProgXZero = GetUserDRO(1213)
     ProgYZero = GetUserDRO(1214)
     ZtoProbe = GetUserDRO(1216)
Case Else
     ProgXZero = GetUserDRO(1205)
     ProgYZero = GetUserDRO(1206)
     ZtoProbe = GetUserDRO(1208)
End Select
SetDRO(2,ZtoProbe)
code "G00"
DoOEMButton(104)
While IsMoving()
Sleep 100
Wend
code "G00"
code "G53Y" & ProgYZero & "G53X" & ProgXZero
While IsMoving()
Sleep 100
Wend
If GetUserLED(1001)= 1 Then
DoOEMButton (119)
SetUserLED(1001,0)
End If
If GetUserLED(1002)= 1 Then
code "G20"
SetUserLED(1002,0)
End If
SetOEMDRO(818,LastFeed)
End Sub
Ken
« Reply #4 on: July 17, 2009, 11:20:21 AM »
A friend of mine with the same machine and screenset just got his smooth stepper and is not experiencing the G00 problem that I am. It is a real pain editing these moves out of my toolpaths.
Is there perhaps some setting that I am missing? I would love to get this resolved since I use my mill daily.
Not griping...I love the SS, but would love it more without this problem.
Ken
