May 24, 2012, 07:55:41 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  vb script help needed
Pages: 1   Go Down
Print
Author Topic: vb script help needed  (Read 910 times)
TASOS
Active Member
Offline Offline
View Profile
« on: July 05, 2009, 02:54:40 PM »
Hi every body
If anyone can help me
How can I check to a macro the condition of an input for use it to a tool change procedure?
I found to a tool change macro the command “SystemWaitFor (input1)” but this is a wait for command, I want something like “while input1” or “while not input1” or “if input1 then………”
Thank you all in advance
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: July 05, 2009, 03:33:44 PM »
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Mach_specific_Subroutines/Functions_grouped_by_purpose#Input.2FOutput_signals.2C_Modbus_I.2FO.2C_a_serial_port_and_.22foreign.22_ports
Pages: 1   Go Up
Print
Jump to:
