Hello Guest it is June 11, 2026, 03:40:17 AM
Author Topic: How to add Wizard to the List  (Read 7900 times)
« on: June 27, 2009, 12:28:25 PM »
Need some help here... tried to get some free space by taking some functions out of my main mill - screen.set -
So I would like to make a own small wizard, which should appear in the pull-down Wizard List on the top of mach.
Ok. managed to build small mywizard.set and made a folder with the name "mywizard" under the Addons folder.
Placed mywizard.set there...
but how do I get the mywizard appear in the wizard - list ???
would be glad if someone could help....  my search for "add wizard to list" or something like that is without success.. ::)
thanks
timmi
Re: How to add Wizard to the List
« Reply #1 on: June 27, 2009, 12:41:45 PM »
Re: How to add Wizard - Button to Open Wizard
« Reply #2 on: June 27, 2009, 01:33:29 PM »
Thank You very much Gerry!
Wow!! very fast solution - testwizard is up and running..
next small problem:
want to load the WIzard with a Button in the normal screen.set -
tried to use  the example "LoadWizard(Powerfeedxy)"  but there seems nothing to happen...
ok  - I´m using this code by putting it in a  G-code   M....    .m1s - only the M...  is placed in the Button ....  perhaps that´s the problem ::)
thanks
timmi
« Reply #3 on: June 27, 2009, 06:00:04 PM »
Loadwizard ("PowerfeedXY")
