Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 24, 2012, 07:12:48 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Brains Development
I can Smell your Brain's
Pages:
1
Go Down
« previous
next »
Author
Topic: I can Smell your Brain's (Read 1156 times)
Grand Master B
Active Member
Offline
on:
June 26, 2009, 08:50:10 PM »
Hi Everyone
I have a small problem with my retorfit, everything is working perfect except for one issue. I am using an MPG4 pendant from cnc4pc into an SS board, step mode works fine but my issue arrives in velocity mode. when press enable and rotate the mpg it works fine speeds up and slows down accordingly, but when i rotate the pendant and release the enable button at the same time the axis keeps moving at that speed without any rotation, if i press the enable button it stops. I know one solution is "dont do that" but it could be rather dangerous if left as is. I am no way a programmer and did have a look at the brains but i think the problem is in the area on the input where it is based on the condition (ismoving) it don't seem to check if the enable triggers are still true, far as i can tell, if anyone has an idea it would be greatly appreicated.
Thanks.
Axis_JogRes_SelectorLPT2.brn
(11.91 KB - downloaded 100 times.)
E-Stop_WO_AutoResetLPT2.brn
(2.5 KB - downloaded 84 times.)
Enable-DisableLPT2.brn
(4.47 KB - downloaded 88 times.)
foka4
Active Member
Offline
Re: I can Smell your Brain's
Reply #1 on:
July 02, 2009, 04:03:01 PM »
I'm using the same setup and getting the same behavior. I guess that means your experience isn't an anomoly.
I've mitigated the issue by using velocity jogging mode only in the x100 setting (for coarse positioning). In the x1 and x10 settings, I'm using position jogging mode for exact control, and the overrunning behavior goes away.
With this configuration, I've never had the overrunning behavior cause a crash, and in fact, I've even taken advantage of it for making long, steady moves without the need for programming. Admittedly, it does require a little technique, but it's quicker than typing a G1 move.
For what it's worth, I used keyboard jogging controls for 5 or 6 years, and now that I have the pendant, I could never live without it.
m
foka4
Active Member
Offline
Reply #2 on:
July 03, 2009, 11:18:48 AM »
Here are the brains I'm using. x100 uses Velocity, x1 and x10 use position.
I set this up several months ago, so I don't recall what I changed in the brains to get them to work this way.
In x100, you get fast, smooth jogging for coarse positioning. On my mill, I can zip along at max rapid feedrate, but still position to about .1" in this setting.
I seldom use x10, but it gives a nice 1" per MPG turn. So six cranks is 6", etc. Nice for quickly and accurately jogging the tool an exact distance just by reading the marks on the MPG wheel.
x1 is handy for accurate positioning. I have it calibrated to the MPG dial, so one detent on the MPG is .001". This is invaluable for precision jogging. Note that the CNC4PC pendant has 4 encoder counts per mark on the dial, so you must calibrate accordingly. It's kind of handy - you can actually eek out .00025" jog increments by carefully moving the MPG between detents.
m
Foka4 Pendant Brains.zip
(4.02 KB - downloaded 93 times.)
Grand Master B
Active Member
Offline
Reply #3 on:
July 04, 2009, 07:00:13 AM »
Let play time begin.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
