Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 24, 2012, 06:16:30 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Galil
(Moderators:
smurph
kcrouch
Galil 2133 or DSPMC/IP Motion Controller?
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Galil 2133 or DSPMC/IP Motion Controller? (Read 2231 times)
smurph
Active Member
Offline
Re: Galil 2133 or DSPMC/IP Motion Controller?
Reply #10 on:
April 24, 2010, 01:43:14 PM »
E-stop should be wired to the Galil ICM "abort" signal. Mach will detect E-stop through the plugin.
For a VFD type spindle drive, the plugin uses the Galil OF command (offset) to "adjust" the offset of the voltage on the analog output from 0 to 9.998 volts. The plugin only controls the analog output voltage. The rest of the required outputs (spindle on, clockwise, counterclockwise, etc...) are setup in Mach and are routed through the Galil plugin (if desired) as normal output signals. The plugin operates this way IF the check box for an encoder on the spindle is NOT checked.
Mach does not send Galil commands. The Plugin does. Mach does not read the data record either. That is also a plugin function. It is the plugin's job to read the Galil data record and report the information back to mach. Conversely, Mach tells the plugin what it wants output and the plugin's job is to make it so via the Galil commands.
Enable debugging in the plugin and a GalilDebug.txt file will be created. You will see all of the Galil commands that the plugin sends to the controller.
Steve
SXYGRAMPS
Active Member
Offline
Reply #11 on:
April 24, 2010, 03:25:42 PM »
Thank You Steve that is a great help I can get the axis to rotate properly with the OF command using galil software. I just cant get the plugin to do it. Ill take a look at the log file you mentioned it should shed some light.
SXYGRAMPS
Active Member
Offline
Reply #12 on:
April 24, 2010, 06:53:35 PM »
Hi Steve
The commands being sent by the plugin are not OF they are AC DC and JG it is sending a signal for a servo loop instead. I have looked at plugin configuration and the only choices for spindle is step and direction or servo. there is no choice for vfd. Do I need to use step and direction to get the OF commands?
SXYGRAMPS
Active Member
Offline
Reply #13 on:
April 24, 2010, 08:09:11 PM »
Ok now that I have read youre post over I noticed you said as long as it does not have an encoder. Mine does but I checked that it dosent. that has it working. Now I am going to try to use the encoder in the jog command thanks for stering me in the right direction
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
