Hello,
I have a compumotor M83-135 Controller that I would like to use for a project but I an having troubles with the wiring. The main problem is that the controller has two wires for step and direction each. I was wondering if it was possible to use this type of controller with mach 3. The manual lists the pinout as shown below..
(Pulse Source) (Driver)
Chassis Ground --- NC
Step output (+) --- B
Step Return (-) --- D
Direction output (+) --- A
Direction return (-) --- E
Shutdown output (+) --- C
Output Return (-) --- F
The letters on the left are just reference for the pinout on the driver. The part that is confusing to me is the returns for each signal.
I have also found a link to the manual listed below. The wiring diagram is on page 19
http://www.compumotor.com/manuals/drives/MDrive.pdfAny help would be appreciated.
Thanks in advance,
Jack
