Hello Guest it is June 10, 2026, 02:02:29 PM
Author Topic: PROBLEMS WITH THE MACH BLUE SCREEN SCRIPT  (Read 11363 times)
« on: May 19, 2009, 05:46:27 AM »
HI
IM HAVING PROBLEMS WITH THE MACH BLUE SCREEN SCRIPT
I USE METRIC,,  NOT INCHES
I HAVE TRIED CHANGING IT MYSELF, I CAN'T GET IT TO WORK
I NEED A SCRIPT THAT CAN FIND THE CENTER OF A 40 mm PIPE
AND MOVE AT ABOUT 100mm A MINUTE
CAN ANYONE HELP ME PLEASE?
EDDIE
vmax549
Re: PROBLEMS WITH THE MACH BLUE SCREEN SCRIPT
« Reply #1 on: May 19, 2009, 10:41:27 AM »
Can you post the piece of script giving you problems maybe we can help.
« Reply #2 on: May 20, 2009, 01:10:31 AM »
HI
THANKS FOR YOUR REPLY
CAN YOU HELP ME?
« Reply #3 on: May 20, 2009, 02:08:35 AM »
HI TP
THIS IS A COPY OF THE SCRIPT,,AS YOU CAN SEE ITS SETUP OF INCHES
Rem   VBScript To center probe inside a pipe
If GetOemLed (825) <> 0 Then       'Check to see if the probe is already grounded or faulty
   Code "(Probe plate is grounded, check connection and try again)"
Else
   FeedCurrent = GetOemDRO(818)    'Get the current settings
   XCurrent = GetDro(0)
   YCurrent = GetDro(1)
   Code "G4 P1"         'Pause 1 second to give time to position probe plate
   Code "F4"         'slow feed rate to 4 ipm
Rem   Probe left
   XNew = Xcurrent - 3      'probe 3 inches to left
   Code "G31 X" &XNew
   While IsMoving()      'wait for the move to finish
   Wend
   XPos1 = GetVar(2000)      'get the probe touch location
   Code "G0 X" &XCurrent      'rapid move back to start point
Rem   Probe right
   XNew = XCurrent + 3      'probe 3 inches to right
   Code "G31 X" &XNew
   While IsMoving()
   Wend
   XPos2 = GetVar(2000)
   XCenter = (XPos1 + XPos2) / 2   'center is midway between XPos1 and XPos2
   Code "G0 X" &XCenter      'rapid move to the x center location
Rem   Probe up
   YNew = YCurrent + 3
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   YPos1 = GetVar(2001)
   Code "G0 Y" &YCurrent
Rem   Probe down
   YNew = YCurrent - 3
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   YPos2 = GetVar(2001)
   YCenter = (YPos1 + YPos2) / 2
Rem   move to the center
   Code "G0 Y" &YCenter
   While IsMoving ()
   Wend
   Code "F" &FeedCurrent        'restore starting feed rate
End If
EDDIE
vmax549
« Reply #4 on: May 20, 2009, 08:49:38 AM »
(;-) The code is not in inches but is in UNITS. Just change the numbers to reflect what you need and resave.
Just a thought, (;-) TP
« Reply #5 on: May 20, 2009, 11:47:18 PM »
THANKS GREG
I WILL TRY IT
« Reply #6 on: January 02, 2010, 03:05:22 PM »
Hi
Here is the one i use for mm, look thru the file i have marked in the comments where you can change it
Rem   VBScript to center probe inside a pipe
Else
   Code "F50"         'slow feed rate to 4 ipm OR 50MM/MIN
Rem   Probe left
   XNew = Xcurrent - 25      'probe 3 inches to left OR 25MM
   Code "G31 X" &XNew
   Wend
Rem   Probe right
   XNew = XCurrent + 25      'probe 3 inches to right OR 25MM
   Code "G31 X" &XNew
   While IsMoving()
   Wend
Rem   Probe up
   YNew = YCurrent + 25                          '25MM
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
Rem   Probe down
   YNew = YCurrent - 25                         '25MM
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   While IsMoving ()
   Wend
End If
Good luck
Friedrich
