Hello Guest it is June 12, 2026, 03:08:23 PM
Author Topic: Can you make a DRO Read only ?  (Read 25737 times)
« on: May 14, 2009, 04:30:35 PM »
I put this counter DRO and reset button on my TURN screen.
It increments UP 1 per Cycle Start button press. (Actually an external button to INPUT 1).
Can the DRO be made so that it cannot be selected and a have a value entered by an operator ?
RC
Re: Can you make a DRO Read only ?
« Reply #1 on: May 14, 2009, 06:10:32 PM »
This came up a few weeks ago and there were a few workarounds posted. Can't find it though. :(
I seem to recall something about placing a transparent button on top of it so it can't be accessed? And a way to use a label to display the DRO contents without actually using the DRO.
« Reply #2 on: May 14, 2009, 06:20:00 PM »
I'll dig around a bit more with the search utility.
Thanks Ger.
Another question.
       What can I do to make the counter see the on screen RUN button press as well as seeing the INPUT 1 from the external button ?
RC
Here is the Brain:
« Last Edit: May 14, 2009, 06:23:24 PM by Overloaded »
« Reply #3 on: May 14, 2009, 06:30:40 PM »
Change the run button to some VB script and use an OEM trigger for the external button? Then either one should do the same thing?
« Reply #4 on: May 14, 2009, 07:08:27 PM »
Changed the Brain input to OEM TRIGGER#1. Works well with the external button.
Cant get the proper script in the VB'd RUN button to cycle the counter DRO.
Can you give me an example of the script/syntax ?
RC
« Reply #5 on: February 03, 2014, 06:46:39 AM »
this may help.
' counts M1001  resets M1002
DRO = GetUserDRO(1011)
SetUserDRO(1011 , (DRO + 1))
While IsMoving()
Wend
Kenneth
