Hello Guest it is June 10, 2026, 12:03:42 PM
Author Topic: Help with torch up down  (Read 8788 times)
« on: May 11, 2009, 04:22:18 AM »
okay I have a problem...going through the brains on the torch up and down comand the Z axis is very jumpy.
also have up and down Leds on screen set with THC enable button & led and none seem to do anything...have not tried it with g code just on test bed...Maybe Scott AKA poppabear can help with this???? if he has time...
If I use the shuttle All axis are smooth and liner....it is only when the brain turns on the torch up or down...
Thanks for any help
« Last Edit: May 11, 2009, 03:07:15 PM by fourxfour2 »
Re: Help with torch up down
« Reply #1 on: May 12, 2009, 09:00:58 PM »
hi, on the mach plasma main screen , under the thc on button, there is a setting to control how fast mach moves the z axis. i have mine set to 5.
