Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 24, 2012, 11:56:22 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Success! Mini Machining Center under Mach3 control - Video link
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
Go Down
« previous
next »
Author
Topic: Success! Mini Machining Center under Mach3 control - Video link (Read 40641 times)
0 Members and 6 Guests are viewing this topic.
Dan13
Active Member
Offline
Reply #100 on:
December 16, 2009, 08:51:08 AM »
Spunk,
As you say, you power the LED and the transistor gives you the output signal, which goes into Mach3 like Hood said. for any given sensor the manufacturer would supply a typical wiring diagram. You'll need to use resistors in line with the transistor and the LED to limit the current to the nominal. The resistor values (or the equivalent current) would usually be specified be the manufacturer.
The output signal from the transistor would usually be too low requiring some kind of an amplifier before it's fed into Mach. A simple solution would be using a schmitt trigger for that purpose.
Daniel
Active Member
Offline
Carnoustie, Scotland
Reply #101 on:
December 16, 2009, 09:59:12 AM »
I use an Optek OPB917B it has everything you need except for a limiting resistor for the LED, 220 Ohm is what I use when powering from 5V.
simpson36
Active Member
Offline
Reply #102 on:
December 16, 2009, 10:24:09 AM »
Photointeruptors come in a lot of different flavors, some costing under US$ 1.00
Some have lenses over the LED and some do not. Some have wires attached and some have only bare pins. Some have polycarb housings and some use much cheaper plastic. Some are rated for vibration and some not . . etc. etc.
In order, I have had lots of false signals from stray light and dust with the un-lensed parts, pins break off very easily on the parts with bare pins sticking out (in fairness, these are meant to be mounted on a PCB, not have wires hanging off them), plastic housings that dissolve seemingly in anything except distilled water, and finally, some just litterally fall apart. The 4th axis was the 'acid test' that killed a number of these parts, some of which were actually working fine as homing switches.
After the above experience with various recommended products, I have settled on the following rather expensive unit US$ 7.25 approx. It has wire leads, lenses covering the optics (to keep out dust and swarf), an indestructible polycarbonate housing that can bend a .060 aluminum tab that gets out of line and hits it, and can tolerate vibration.
It is a Honeywell model HOA 1887-012
I now have these on all of my machine axis and also on the 4th axis and they will be used on the commercial verison of the 4th axis as well. You simply need a 100 to 150 ohm resistor on the 5V that feeds the LED (red wire) You can use 5V or up to 30V for the trigger side. For example if you use 5V from a BOB, you can daisy chain 3 of these and still have 3.5V return to the BOB. I have a little "Remote LED driver board" to boost signals, but it has not been necessary to use with these Honeywell interrupters and the Homann designs BOB.
Peralta
Active Member
Offline
Reply #103 on:
January 26, 2010, 01:49:56 AM »
You have done a great job, and I hope if you have time you show all your works. I think it's been a long time when you finish this study. I am very interested in what you have done.
simpson36
Active Member
Offline
Reply #104 on:
January 26, 2010, 05:23:59 AM »
Thanks!
The X2 featured here is now sold and gone. My new mill is scratch built completely from aluminum and is slightly larger than an X3. There are still some details to finish up and the high speed pulleys are not done yet, but I have just started cutting metal with it. I will be posting photos and videos soon. Unfortunately I do not have time to do a build thread on CNCzone or anything like that.
Here is the latest video which simply demonstrates the newly finished pneumatic spindle lock on the 4th axis. I now have a larger disk and an new belt guard (not shown in the vid) extends to cover the new disk.
http://www.youtube.com/watch?v=glYDe94hxb0
Flying Scot
Active Member
Offline
Reply #105 on:
January 26, 2010, 05:55:26 AM »
Hi Simpson
I am also building an indexer based on your design.
I think I may be using too small a servo (150watt) so was intending to use a brake or locking system.
I don't intend using heavy cuts but most of the parts will be 5" aluminium.
How does you brake work is it just by putting pressure on the outside of the belt?
Regards
Arthur
simpson36
Active Member
Offline
Reply #106 on:
January 26, 2010, 08:19:38 AM »
It is a disk brake. The disk is .062" 2024 aluminum and is intended only for holding and not for stopping. The servo motor provides deceleration. The mechanical disk caliper is from a 'pocket bike'.
The lock was 'added on' and not part of the original design, so it could be better integrated, but other than having the disk extend past the frame (which requires an elaborate belt guard), everything worked out satisfactorily.
The servo drive is a 'Dugong' model from CNCdrive and they are modifying the firmware for me so that the drive's max amps can be set back a fixed amount under software control. This will coordinated with the lock event. The purpose of this is to prevent the motor from overheating if it disagrees with the location of the lock event. Keeping the amps below the motor's continuous rating will prevent possible overheating and damage to the motor.
simpson36
Active Member
Offline
Reply #107 on:
January 26, 2010, 09:12:15 AM »
Here are a couple pics of the new mill showing the spindle lock. In this case, I may want to use the brake for stopping the spindle, so it is a thicker steel part.
Next photo shows nearly fial assembly. Belt guards nor installed yet, etc.
Flying Scot
Active Member
Offline
Reply #108 on:
January 26, 2010, 04:06:28 PM »
Thanks for the pictures.
I can see the brake clearly now.
You mention the problem of the servo dithering while at rest. If was only going to use the 4th axis as an indexer would I be better using a stepper motor instead?
Regards
Arthur
Active Member
Offline
Reply #109 on:
January 26, 2010, 04:21:12 PM »
Quality job there Simpson
Quote from: Flying Scot on January 26, 2010, 04:06:28 PM
Regards
Arthur
You could use a stepper but also with a servo you could have a macro so that when you apply the brake you disable the drive a split second later, that would solve any tripping problems.
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
