Hello Guest it is June 09, 2026, 07:14:04 AM
Author Topic: Screensavers & Mach3  (Read 8863 times)
« on: August 10, 2006, 12:21:19 PM »
Has anyone noticed that when Mach is in 'reset' mode the Screensaver never turns on.  However, when I am runing a long program the screensaver DOES come on.  The program still runs fine except the Tool Path Trace stops while the Screensaver is runing.
OK, so this is probaly the most frivolous of concerns but, this is backwards to me.  Shouldn't the Screen save turn on when the machine is in reset and NOT when it is runing a program?
Just Curious,
Sid
Re: Screensavers & Mach3
« Reply #1 on: August 10, 2006, 09:17:52 PM »
This is a driver thing :( You need to turn off the screen saver... they are not needed any more ;)
www.newfangledsolutions.com
www.machsupport.com
