May 24, 2012, 11:49:09 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  Setting up a 4th Axis (new to CNC)
Pages: 1   Go Down
Print
Author Topic: Setting up a 4th Axis (new to CNC)  (Read 1046 times)
obiewan
Holding
Offline Offline
View Profile
« on: May 03, 2009, 03:10:09 PM »
Pardon my newness, but I have run into an immediate snag.  Sorry if there is a post on this already, as I searched but didn't find.  My machine actually uses 2 stepper motors to run the Y axis--one on each side of the gantry.  Each motor is run to its own driver control.  I set up the usual X, Y, and Z axes per setup tutorial videos and also added an A axis (as my second Y).  The A axis motor needs to mimic the Y axis motor.  Can I set this up using Mach 3, or do I have to account for the 4th axis in g-code?
The good news is that the software setup went fine, the parallel port is getting healthy readings, my wiring is fine, and I am able to jog on all 4 axes.  The bad news is that when I try to run a test program, only one side of my table's y axis moves (the side I designated Y--the A axis side gets no code info, so it doesn't move).  Hopefully this is an easy fix as I do not want to tediously fix g-code if I can avoid doing so.  Thanks for the help.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: May 03, 2009, 03:53:05 PM »
Lokk in config, slave axis. You will want to slave the a to the Y.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Pages: 1   Go Up
Print
Jump to:
