May 24, 2012, 10:56:08 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  Feed rate on start up.
Pages: 1   Go Down
Print
Author Topic: Feed rate on start up.  (Read 831 times)
Jens H
Active Member
Offline Offline
View Profile
« on: April 22, 2009, 07:06:27 AM »
When I start mach3 the Feed rate is 6 (6mm/min--very slooow)
When i JOG this feed rate is used. I can change it, but next time i start Mach3 it is 6 again. Where can I change this value so it's default?
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #1 on: April 22, 2009, 08:46:30 AM »
Put it in the initialisation string in general config
F1000 for example.
Greg
Jens H
Active Member
Offline Offline
View Profile
« Reply #2 on: April 23, 2009, 01:58:28 AM »
Thanks. That do the trick.
Pages: 1   Go Up
Print
Jump to:
