Hello Guest it is June 10, 2026, 08:33:54 PM
Author Topic: block some parameter  (Read 11705 times)
« on: April 13, 2009, 06:33:14 AM »
if i use mach3 can i block some parameter or i can make some stranded program for the operator to use without changing main parameter in my mach 3 and how can i do that?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: block some parameter
« Reply #1 on: April 16, 2009, 02:56:16 AM »
I do not fully understand what you are saying BUT you can have different "versions" of Mach 3 for different applications, each with it's own set of parameters.
« Reply #2 on: April 16, 2009, 04:11:00 AM »
i'm sorry but i mean after i setting my mach mill and for example calibrate the motor and sell it i'm in need to prevent user to change calibration and my be other parameter can i do this in mach 3
« Reply #3 on: April 16, 2009, 04:15:58 AM »
Go to Operator menu then Lock, you will get a box appear asking for a password, type in the password you want to use (there is a default there so make sure you enter your own instead) Once that is done none of the config settings can be altered or even opened. To Unlock its Operator menu then Unlock, enter your password and then you can change Config.
Offline hhr08
  •  27 27
default password to unlock and lock system settings under Operator Menu
« Reply #4 on: July 18, 2011, 04:11:17 PM »
can someone email me the default password to unlock and lock Mach3 settings under Operator Menu.
Thanks.
rkelemenhhr@hotmail.com
« Reply #5 on: July 18, 2011, 04:18:15 PM »
Try None or Mach1Pass
Offline hhr08
  •  27 27
« Reply #6 on: July 18, 2011, 04:26:09 PM »
thanks Hood,
by the way
 my "drilling a hole to china problems" turned out to be a C10 breakout board.
everthing is running right now like a swiss watch.
bob
« Reply #7 on: July 18, 2011, 04:28:42 PM »
Thats good, thought it was a hardware issue :0
