Hello Guest it is June 11, 2026, 01:51:20 PM
Author Topic: NEED HELP  (Read 9838 times)
NEED HELP
« on: April 12, 2009, 05:17:22 PM »
I GET A MESSAGE, REQUESTED HOME AXIS HOME SWITCH IS ACTICE, PLEASE FIX. HOW DO I FIX? THIS IS ON A MACH3 SYSTEM.
« Last Edit: April 12, 2009, 05:20:13 PM by inivator »
Re: NEED HELP
« Reply #1 on: April 12, 2009, 05:42:34 PM »
Do have a home switch? If not go to ports and pins and disable it. If you do then either your machine is activating the switch or you have a faulty switch or you have the active state for that switch set wrong.
Re: NEED HELP
« Reply #2 on: April 12, 2009, 05:57:19 PM »
THANKS FOR THE HELP. I'LL TRY IT.
