Hello Guest it is June 10, 2026, 02:58:37 AM
Author Topic: Completely automatic running of Mach3  (Read 6766 times)
« on: April 11, 2009, 11:01:56 AM »
Hello All
I am working on a project where a C++ program I am writing must start up mach3 and get it loaded and running completely automatically.
I have created a really basic macro which uses the "runfile" command and have placed it into the initialization string on the general configuration. The C++ program then starts Mach3 from the command line. This almost works however there is still a need to press the "Reset" button. Is there a way of running without the need of reset???
Any help would be much appreciated.
Benjamin
vmax549
Re: Completely automatic running of Mach3
« Reply #1 on: April 12, 2009, 10:43:06 AM »
There should be a button that can togle RESET check for the proper Command and add it to your macro???
Just a thought , (;-) TP
