Hello Guest it is June 13, 2026, 06:51:44 AM
Author Topic: Screendesigner "machscreen"  (Read 340021 times)
Re: Screendesigner "machscreen"
« Reply #150 on: August 17, 2009, 11:58:46 AM »
Version V1.25.0 can be downloaded from my site.
I fixed the "paste in higher page numbers" problem.
Added a new checkbox "Pos selection" in the property dialog. When this checkbox is set and ctrl V is pressed, a dialog appears asking how to paste (actual, all, or selected pages) on original position, or from upper left to lower right positions. If unchecked the selected obj. is pasted into the actual page from upper left to lower down positions.
Added copy and paste feature of edit fields within the property dialog.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #151 on: August 17, 2009, 03:30:07 PM »
Thanks Klaus!!!!!!
« Reply #152 on: August 17, 2009, 04:46:37 PM »
Hi Klaus,
    A few dumb questions if I may, I went to page 60, I added 3 buttons, so how do I
1). copy the text out of the properties box, could not figure out how to highlight it to copy it.?
2). How do I paste it into another buttons box tried to highlight then delete, then hit Ctr-V and couldnt paste into it?
3). If I leave the properties box, how do I get my cursor to get back at the end of the words I have already put in there
without it erasing the letters?
Scott
« Reply #153 on: August 18, 2009, 04:27:00 AM »
Hi Scott,
1) go to page with source text, select object, doubleclick the text to copy in the property dialog (background color changes to blue) press ctrl C.
2) go to page where you want to paste the text, select object, doubleclick the text where to insert the new text (background color changes to blue) press ctrl V.
3) doubleclick the text you want to edit, press cursor right key.
If this doesn't work, please tell me.
Klaus
« Reply #154 on: August 18, 2009, 08:02:08 AM »
As Usual, you fixed it!!!
Thank You ONCE AGAIN!!!!!
Scott
« Reply #155 on: September 03, 2009, 01:46:23 PM »
Hey all
I released version 1.26. Here some info's about v1.26
Additional checkboxes and settings in options -> settings  generic prog settings.
1) "Use larger font edit fields". When checked, the text is shown with a slightly larger font.
2) "Set edit text selected". When checked, the whole text is selected at first double click.
3) When in edit field "cycle time" a value > 0 is entered, the actual data is stored cyclic. In case of an abnormal termination of the program at next start, a messag box asks whether to reload, or ignore  this stored data. The value must be between 0 and 2880. Important !   This cyclic storage doesn't work when a "New" design is started, you have to execute the "save", or  "save as" command, in order to enable this feature.
The cursor can now be positioned within the edit field by the mouse.
New menu item options -> "Set MachScreen as default screen editor" added. Meaning, if MachScreen is not running, double clicking a set-file with the explorer, starts MachScreen  and loads the set-file.
When a larger number of objects were selected with the rubberband, the selection could get scrumbled, fixed
Klaus
« Reply #156 on: September 03, 2009, 07:19:56 PM »
Thanks Klaus. Your great.
Offline ataxy
  •  31 31
« Reply #157 on: September 06, 2009, 06:28:31 PM »
in the english vesion there is a button that as not been translated under setting/language tab button is called ''alle''
« Reply #158 on: September 07, 2009, 01:57:46 AM »
Danke Schön Klaus!
Is there a trick to use the "multiple select" drag box? (left click and hold)
Am I doing something wrong or it is not 100% yet?
thanks,
francis
« Reply #159 on: September 07, 2009, 02:18:35 AM »
Hey Francis,
to throw the rubberband around objects, the starting point must lie outside of any object, otherwise you would select the smallest object hit by the mouse. If you selected unwanted objects by doing so, you can deselect them, by holding down the shift key an clicking each unwanted object.
Klaus
