February 13, 2012, 01:14:16 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Finished Screens
| | | |-+  Mach3 Aqua
Pages: « 1 2 3 4 5 6 7 8 »   Go Down
Print
Author Topic: Mach3 Aqua  (Read 23590 times)
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #10 on: May 16, 2009, 07:53:52 AM »
Thanks, Scott. Smiley
bladerunner
Active Member
Offline Offline
View Profile
« Reply #11 on: June 06, 2009, 08:51:33 PM »
THAT LOOKS WICKED!
very slick and smooth thanx for your hard work!
cheers
Haydn
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #12 on: June 06, 2009, 08:55:13 PM »
 Version 1.04
Changed A axis scale to Rotation Diameter for 4 axis work. Should have always been this way. The A Scale button image is included if you want to change it back.
Removed Z axis Auto Zero button. Replaced with Go To Safe Z.
Added Flyout window for Ernie's Probing routines.
http://cnczone.com/forums/showthread.php?t=56079
I copied these from Ernie's modified Mach Blue screenset.
These can be accessed with the TAB key, or by clicking the Artsoft logo (for Bob and his touchscreen )
Also added a (very) short .pdf manual.
http://tinyurl.com/pz8az9
sshneider
Global Moderator
Offline Offline
View Profile
« Reply #13 on: June 11, 2009, 12:14:36 AM »
This is a REALLY nice Set.  Elegantly Simple but not 'dumbed down'.  I wish I were 25% as creative!  WOW!!
Sid
penmaker1
Active Member
Offline Offline
View Profile
« Reply #14 on: July 22, 2009, 06:34:18 AM »
Very nice screen set Ger.  I resized it to 800 x 600 using ScreanTweak for my LCD with touch panel in the shop, It look awesome on that display,
Thanks for your hard work on this.
John Guenther
'Ye Olde Pen Maker'
Sterling, Virginia
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #15 on: July 22, 2009, 08:07:12 AM »
No problem. Whatever happened with the Flash Docs? Wink
vintageracer
Guest
« Reply #16 on: October 08, 2009, 09:23:20 PM »
Hi Gerry,
Great screen set. One of the best I've seen so far. I use it daily on my retro-fitted Dyna Mechtronics DM4400.
Brilliant screen layout and super easy to see at a distance.
Two questions.
On the 'run' screen why is one of the override reset buttons 'on' and the other 'off' when both are at 100%?
On the 'machine settings' page is it possible to get a 'goto zero' button put in?
Perhaps replace the 'G90.1' and the G91.1' buttons with 'goto zero' and 'ref all home'?
Timothy
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #17 on: October 09, 2009, 10:35:35 AM »
The Spindle override reset doesn't work correctly unless you call for a spindle speed first. Try putting S5000 in the initialization string.
I'll look into the other ones.
vintageracer
Guest
« Reply #18 on: October 09, 2009, 11:40:43 AM »
I have spindle speeds attached to every tool change, but should I insert one before the first M6?
I'll give it a try.
Timothy
vintageracer
Guest
« Reply #19 on: October 09, 2009, 02:07:03 PM »
No, no difference.
Pages: « 1 2 3 4 5 6 7 8 »   Go Up
Print
Jump to:
