Home
Downloads
Mach and LazyCam
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Known Bugs
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
February 04, 2012, 06:00:58 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
Mach Screens
Finished Screens
Mach3 Aqua
Pages:
1
2
3
4
5
6
7
8
Go Down
« previous
next »
Author
Topic: Mach3 Aqua (Read 23390 times)
ger21
Global Moderator
Offline
Mach3 Aqua
on:
April 05, 2009, 03:22:48 PM »
I wanted to add some more to this, but do to limited time, this is as far as it'll get.
There are 2 brains required. One for the spindle override, so it matches the FRO, and one for the Offset buttons. Make sure both are loaded and enabled. If you're code doesn't contain a spindle speed (like S5000), the LED may not work correctly. One workaround is to put an S********* in your initialization string.
place all the .png's in Mach3\bitmaps\Aqua\
and Aqua.set in Mach3\
brains in Mach3\brains\
This version is the same as the last I posted, with the addition of the offset buttons changing color to match the current offset.
Enjoy.
http://tinyurl.com/dfogtg
EDIT: The latest version is here:
http://tinyurl.com/pz8az9
Last Edit: July 19, 2009, 02:10:51 PM by ger21
http://home.comcast.net/~cncwoodworker/2010.html
Greolt
Global Moderator
Offline
Re: Mach3 Aqua
Reply #1 on:
April 05, 2009, 06:15:17 PM »
Very nice Gerry.
You have put a lot of work into that. Well done.
Greg
ger21
Global Moderator
Offline
Re: Mach3 Aqua
Reply #2 on:
April 05, 2009, 08:55:41 PM »
Thanks. Probably 100 hours in Photoshop.
Greolt
Global Moderator
Offline
Re: Mach3 Aqua
Reply #3 on:
April 05, 2009, 10:33:11 PM »
100 hours.
That could have been spent building your router.
Greg
ger21
Global Moderator
Offline
Re: Mach3 Aqua
Reply #4 on:
April 12, 2009, 10:23:52 AM »
Someone at CNC Zone posted a video of their machine, with a few seconds of the screen in action.
http://www.youtube.com/watch?v=OOesDXSxzqI
ger21
Global Moderator
Offline
Re: Mach3 Aqua
Reply #5 on:
May 09, 2009, 10:34:49 AM »
Here are the Photoshop files, if anyone wants to modify these screens. It's a 20+MB download, though.
http://tinyurl.com/pps585
There is a main file for each page, with each control on it's own layer. I turn most of the layers off to export the .png. Look at the actual .png files in the bitmap folder to see how I did it.
Because of the gradient backgrounds, buttons aligned left to right can share the same background. So you should find a single file for each horizontal row of buttons (in each control section). You can change the text and export a different .png for each button. You'll notice that there is duplicate text on buttons with the drop shadows. One under the highlight, with the drop shadow, and one above the highlight, without the shadow. This keeps the shadow below the highlight, and the text on top where it's more legible.
keithmech
Active Member
Offline
Re: Mach3 Aqua
Reply #6 on:
May 13, 2009, 10:26:53 PM »
is it possible to modify this screen with the screens program?
I want to have only xyz axis.
ger21
Global Moderator
Offline
Re: Mach3 Aqua
Reply #7 on:
May 14, 2009, 07:56:06 AM »
You'd have to modify the Photoshop files and use a screen designer to modify the controls on the screens. If you just want to remove some things, it shouldn't be too hard.
ger21
Global Moderator
Offline
Re: Mach3 Aqua
Reply #8 on:
May 16, 2009, 07:25:55 AM »
Update.
Added some buttons to the jogging area. Added a + and - to adjust the slow jog %, and for the incremental jog, added 3 buttons. Inc. cycles through the increments set in General Config. + and - increase and decrease by .1 on my machine. Not sure if this is settable anywhere?
CV Button. On the Settings page, the G64 "button" was just an LED. It's now a button that toggles between G61/G64.
Last thing, Pause LED. Not sure if it works, because it doesn't work in the version I have installed, 3.043. Can someone let me know if the pause button flashes when paused, and what version you're running if it does. I've heard the Pause LED works in the lockdown versions, but not the development (maybe just some?) versions.
http://tinyurl.com/ptdg5g
Last Edit: May 16, 2009, 07:27:41 AM by ger21
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Re: Mach3 Aqua
Reply #9 on:
May 16, 2009, 07:52:20 AM »
Gerry,
I really like what you did to compact the Jog, (and your screen in General), super nice work!!!
Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP motion controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Loading...
