Hello Guest it is June 11, 2026, 02:48:00 AM
Author Topic: smooth stepper port 2 pin assignment  (Read 14134 times)
« on: April 04, 2009, 05:55:16 AM »
hello,
it is not cler to me if I manage the port 2 as 13 input and 4 output configuration wich pins will be assigned to output. Sorry if the question seems dummy but it is not realy clear to me :)
Thanks in advance for the help
Re: smooth stepper port 2 pin assignment
« Reply #1 on: April 04, 2009, 08:06:49 AM »
Same as the parallel port, 1, 14, 16, 17
« Reply #2 on: April 04, 2009, 08:46:48 AM »
« Reply #3 on: September 03, 2009, 03:42:29 AM »
On the SS website an old documentation is available only...
Can someone tell me the PINOUT for the SS board?
I mean if I set PIN x on mach, which PIN on the SS connector will be affected.
On the docu. one of the connectors is numbered but to me it looks odd, those connectors usually use PIN1 on the opposite side (at least with floppy drives as I recall...)
So what I need is a consistent chart for PIN numbering on the SS board, and MACH pin numbering...
Anyone can help???
OK, Not an issue anymore, As I made a few measurements it seems pinout is as written on SS manual... Problem solved from my side.
« Last Edit: September 06, 2009, 12:46:32 PM by hunserv »
