Hello Guest it is June 13, 2026, 08:04:39 AM
Author Topic: UPDATE to Mach Specific VB routines and VB Params!!  (Read 7763 times)
« on: March 31, 2009, 03:52:27 PM »
Here is the link to the Member Docs on the support site.
http://www.machsupport.com/forum/index.php/board,78.0.html
The Thread called: UPDATE to Mach Specific VB routines
has the "Undocumented" VB as an extension to the Wiki docs.
The Thread called: VB "Parameters list....."
has the List of VB controlled parameters (some undocs there too).
scott
Re: UPDATE to Mach Specific VB routines and VB Params!!
« Reply #1 on: April 01, 2009, 09:35:51 AM »
GOOD NEWS!!!!  Art filled in my blanks/Unknowns so now BOTH the Parameters and Mach Specific VB is now Complete!!
So RE-Download the docs or copy it out of the Member Doc Windows
Scott
vmax549
« Reply #2 on: April 02, 2009, 04:17:59 PM »
HIYA SCOTT,  GOOD job on the Parameters(;-) I add it to  the manuals here.
Could you pry out of ART the full ranges of the
Led            x------*********
OemLed     X-------*********
UserLed     x--------*********
Dro            x--------*********
OemDro      x--------*********
UserDro       x---------*********
Button        x---------*********
OemButton  x------*********
UserButton  x-------*********
Maybe an updated and sorted list of all the known ones. I do have the published list in Spreadsheet format and I have it in catogories then filter 4 layers. It is simple to use that way.
Glad to donate it IF you need it. May need to update the info (;-)
ALSO a pfull published list of all the SYSTEM VARs would be nice. I know they go from 0=null to 10,320
0-499
500-600 persistant
601-1999
2000-2003 G31 data
2004-5160
5161-5166 g28 values
5181-5186 g30 values
5211-5216 g92 values
ETC,ETC
Be glad to sit down and do a spreadsheet for these IF it would be of help.  I know there are many other hiding in there(;-) It might Jog ART 's memory.
MIght be a good idea to do a program to search mach files and register all know used Vars,param,led,dros,etc used in current MACH code.
Just a thought, (;-) TP
« Last Edit: April 02, 2009, 04:23:32 PM by vmax549 »
« Reply #3 on: April 03, 2009, 09:07:30 AM »
Brett, had asked me and a few others to contribute to a "Skeleton" function listing "Parameter type system. Brian has already mentioned this here, and on the Yahoo forum.  So at this point, I will not be doing any more to the "Old" system, since it appears they will be incorporating a new format.
Please feel free to add, or improve on the stuff I put out in any way you think would be helpful.
scott
