May 23, 2012, 10:46:46 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  crazy outputs from simple code.
Pages: 1   Go Down
Print
Author Topic: crazy outputs from simple code.  (Read 794 times)
turbine
Active Member
Offline Offline
View Profile
« on: March 26, 2009, 02:56:07 AM »
I am trying to retune tune my drives (dc servos) since converting from P.P. I have 1 drive running at full speed now but still have a problem.
To tune, I use the following piece of code to save manually jogging back and forth.
F3000
G01 x50
x0
x50
x0
x50
x0
The problem is if I run this code with NO FRO. i.e. 100%, it will travel at 2300ish mm/min for all but the last line of code! for which it runs as instructed at 3000 mm/min?Huh?
Any help pleeeease.
Cheers,
James
boilerbots
Active Member
Offline Offline
View Profile
« Reply #1 on: March 30, 2009, 04:41:08 AM »
Use Mach3 R3.042.024 and the latest drives for the SS board.
Also what is your acceleration for the X axis and do you have CV mode enabled?
Pages: 1   Go Up
Print
Jump to:
