Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2012, 10:38:22 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Newfangled Solutions Wizards
(Moderator:
Ron Ginger
CNC newb needs Wizard or Help with G code for K baffle
Pages:
1
Go Down
« previous
next »
Author
Topic: CNC newb needs Wizard or Help with G code for K baffle (Read 2266 times)
MAKESOMECHIPS
Active Member
Offline
on:
March 23, 2009, 02:40:06 PM »
I just got my CNC machine up and running finally Very Happy
It is a Shopmaster Eldorado lathe bridgemill.
I am using Mach3 to run the machine and I didn't see any wizards that came with the program that would be easy to cut the K baffle. Again I am a newb on the CNC so there may be one there and i am not smart enough to find it let alone to run it yet.
But if someone knows of an easy wizard to use for that purpose or has the code already that they wouldn't mind sharing I would greatly appreciate it.
this is a K baffle
http://www.cncguns.com/images/P3270443.JPG
Jamie
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Re: CNC newb needs Wizard or Help with G code for K baffle
Reply #1 on:
March 24, 2009, 07:01:19 PM »
Under Lathe use the Lathe Shapes wizard, to do the outside, (holes side toward the chuck), do an outside taper, and then do an inside boring taper.
then under Mill, Use the Circular Hole patter wizard to do your perifial holes.
s.
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
MAKESOMECHIPS
Active Member
Offline
Reply #2 on:
March 24, 2009, 07:19:58 PM »
when i go into lathe wizards i do not see the lathe shapes. The wizards look the same as the mill wizards maybe i do not have that pack installed.
thanks
Jamie
Ron Ginger
Active Member
Offline
Reply #3 on:
March 26, 2009, 08:25:04 PM »
You will only see the lathe wizards when you are running the Turn version of Mach. If you only see the mill wizards you are running mill.
Global Moderator
Offline
Reply #4 on:
March 26, 2009, 10:34:08 PM »
JAMIE,
There are a whole bunch, just piece them together for what you want to do or use individualy.
Welcome to the world of CNC.
MAKESOMECHIPS
Active Member
Offline
Reply #5 on:
March 27, 2009, 06:31:15 AM »
Thank you Ron and Rich
I might have to reinstall the program on my cnc computer. I installed it on my work computer just to try some things and the above lathe wizards are there but on my cnc computer i cannot find them.
Is there a way to reinstall Mach3(ie a folder to copy or something)without losing my motor tuning and port and pin settings?
Ron Ginger
Active Member
Offline
Reply #6 on:
March 27, 2009, 06:46:57 AM »
If you followed the recommendations in the Install manual you created your own profile and xml file. Then when installing a new version of Mach your file will not be changed.
If you are running on the default xml mach usually does not alter it on a re-install, but there are cases when it has,
In any case all of your custom settings are in your profile XML file and only that file needs to be saved.
I doubt a reinstall will fix anything. Mach determines from the profile it starts up what screen set to run. If its told to tun a .lset it means a lathe setup and the wizards are pointed to the correct lathe wizards.
Try to select the lathe screen set and see if Mach then thinks its running on a lathe.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
