Hello Guest it is June 10, 2026, 03:32:05 PM
Author Topic: moh_kushly  (Read 11030 times)
moh_kushly
« on: March 20, 2009, 01:35:45 AM »
I
How do I reference the digital input #1 in the OEM triggers
I am using G100 controller
Re: moh_kushly
« Reply #1 on: March 20, 2009, 07:12:52 AM »
You will go to config., ports and pins, inputsignals, Oem Trigger and set the pin you want to use there. Then go to config., system hot keys and assign and oem number to the trigger.  See attached pics.
Re: moh_kushly
« Reply #2 on: March 21, 2009, 03:31:57 AM »
Thanks Chaoticone for help.    That exactly what i was missing.
But what about the Analouge inputs and outputs ,  Icant find  any place to configure them,   can you help please
Re: moh_kushly
« Reply #3 on: March 21, 2009, 12:08:07 PM »
Look at the top of this page, support, documentation, G100 Set Up Guide. Some of the normal analog controlled features such as Feed Rate Override will not work with the G100. It was a hope at one time but never matured.
