May 23, 2012, 10:29:02 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Question: Some minor GUI irregularities or quirks
Pages: 1   Go Down
Print
Author Topic: Question: Some minor GUI irregularities or quirks  (Read 992 times)
Eureka-Tech
Active Member
Offline Offline
View Profile WWW
« on: March 19, 2009, 11:39:20 PM »
I'm new, but have dealt with other customizable CNC controller interfaces and I have a few questions:
- Using the Screen4 designer I cannot get the DRO text to center with a border. It looks like the edge of the numbers are cut off (sitting right on the DRO box bottom), is there a way to control text height?
- The DRO has a shadow even when the color is the same as the background, any way to get rid of that (to make the readout flat)?
- Is it possible to eliminate some of all the top menu (pull-down) options, or to completely remove the top menu (hide it)?
- I assume the .\mach3\splash.bmp can be changed to be whatever we want (will try that), can it be an animated GIF or BMP as well?
- Can transparent images be utilized to make "Vista-like" effects on the screens?
- Can the whole GUI be border-less or theater-mode for us to design everything on the GUI?
- Can a button be made to exit the program (I would guess YES)?
- Any way to change Mach3 screenSET fonts with the Screen4 designer?
Thank you all for a great user experience and strong CNC controller.
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: March 22, 2009, 09:01:52 PM »
Hi Eureka-Tech ,
You are asking under the Mach interface using Adobe Flash products page Smiley
I will move this topic to Screem4 section  Wink
Regards, Jason Blake
www.Fusioncnc.com
Pages: 1   Go Up
Print
Jump to:
