Hello Guest it is June 10, 2026, 09:21:21 PM
Author Topic: VB syntax  (Read 31751 times)
Re: VB syntax
« Reply #20 on: March 22, 2009, 09:14:56 AM »
Jusst another side note:
you have to set the vars before you can use them.
you have this:
'M79.m1s
GetVar (550)
Code"#551=[#550/2]"
You need this:
'M79.m1s
Var1 = GetVar (550)
SetVar (551, (Var1/2))
'When ever you use a "Get" something, you have to set it = to something, OR, put the Get as the parameter of another function.
'for example
SetVar (551, (GetVar (550)/2))
'scott
« Last Edit: March 22, 2009, 09:17:27 AM by poppabear »
Re: VB syntax
« Reply #21 on: March 22, 2009, 10:50:50 AM »
I think you may be missing the fact that
Code"#551=[#550/2]"
does set 551. In reality, I don't need
GetVar (550)
Variable 550 is set in the calling G-code and I could either set 551 as I am doing in the macro or with
#551=[#550/2]
in the G-code following the #550=  line.
Re: VB syntax
« Reply #22 on: March 22, 2009, 03:21:03 PM »
Hi
You appear to be confusing integers with strings and are showing a integer value within string quotes
The below is not strictly necessary but clearly shows the difference between the 2 types of data you are combining.
(   Str() converts an integer to a String and Val() does the reverse  )
Dim V As Double
Dim s1 As String
V= GetVar (550)
s1 = "G90 G00 X" &Str(V) & " Y" &Str(V)
Code s1
regards
Melee
Actually, when I first set V with
V= GetVar (550)
I am implicitly declaring V as Double. The same is true when I then set V1 with
V1=[V/2]
because the value being set is Double.
Re: VB syntax
« Reply #23 on: March 22, 2009, 09:24:14 PM »
Well all righty then, you got it all figured out then
Good luck
scott
