May 23, 2012, 10:02:05 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  G81 canned drill routine too slow to position
Pages: 1   Go Down
Print
Author Topic: G81 canned drill routine too slow to position  (Read 865 times)
jsmithwe
Active Member
Offline Offline
View Profile
« on: March 14, 2009, 11:15:38 AM »
I am trying to figure out how to change the feedrate to rapid position between holes in a 28 hole g81 routine.  My code looks like this:
G81 x0 y0 z-0.9 ro.1 f5
x1.25
y0.75
x0
y1.5
and so on......
The feedrate f5 is great for drilling but way too slow when positioning.
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: March 14, 2009, 02:18:03 PM »
G0 and G1 are modal. That is what it will do until told to do something else. G0 is Rapid and G1 is a feed.
G0 X0 Y0
G1 F5 Z-0.9
G0 Z 1.25
X 1.25 Y 1.25
X -1.25
Y -1.25
G1 F5 X 1.25 Y 1.25
X -1.25
Y -1.25
If you have space, run this program and see the actions produced by each line. Then you can run it in single block to help even more. Run it slow and watch it good to make sure your not going to crash and be ceratin all is well.
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Chip
Global Moderator
Offline Offline
Gainesville Florida USA
View Profile
« Reply #2 on: March 15, 2009, 09:32:23 PM »
Hi,Jsmithwe
It looks like it's moving with a rapid between hole's hear, What version of mach3 are you running, Look under, Help, About.
G81 x0 y0 z-0.9 r0.1 f5
x1.25
y0.75
x0
y1.5
G80
M30
First pic is, Hole being drilled, Second is, Rapid between hole's
Chip
« Last Edit: March 15, 2009, 09:37:21 PM by Chip » Logged
jsmithwe
Active Member
Offline Offline
View Profile
« Reply #3 on: March 16, 2009, 02:48:40 PM »
Thanks for making me look.  It DOES rapid between holes.  Nevermind but thanks.
Pages: 1   Go Up
Print
Jump to:
