Hello Guest it is June 11, 2026, 10:03:20 AM
Author Topic: DRO's Do Not "ZERO" When Homed  (Read 12461 times)
« on: March 09, 2009, 03:30:21 PM »
I cannot understand why the attached ITCAM xml, when run in simulation, will NOT ZERO the axis dro's when completing the routine.
Emulating the sw. with hotkeys.....X for x and Z for z.
SHOP xml works as it should, ITCAM xml doesn't.
I can't figure out why.
Would you mind to check it out for me ? Maybe show me what's hosed ?
RC
Re: DRO's Do Not "ZERO" When Homed
« Reply #1 on: March 09, 2009, 04:52:30 PM »
Rc, I haven't downloaded and checked but what are the steps per set to for the axis not zeroing. This could possibly be the problem. If the math will not work out it may be haveing to register more or less than 0. If it can't be divided evenly it can only get as close as possible.
« Reply #2 on: March 09, 2009, 04:57:04 PM »
Homing and Limits, check the AutoZero box.
« Reply #3 on: March 09, 2009, 05:04:58 PM »
Thanks guys.....
Hood, you were right on.
I must have overlooked that 5 times.
Sometimes...I wonder if I'm making any headway.
Learn 1 thing...forget 2.
Should have remembered that !
RC
« Reply #4 on: March 09, 2009, 05:07:04 PM »
;D
