Hello Guest it is June 09, 2026, 11:50:34 AM
Author Topic: Can "Direction" &"Steps" signals be saved and stored in physical "memory"?  (Read 12366 times)
Hi All:
This is just a brainstorm.
Since the role of Mach3 is: Translate G-code into signals of "Direction" and "Steps" to control stepper motors, Can those signals be saved and stored in a physical  "memory"? everytime, while push external "Start" button, CNC-machine run once,...just drectly use those signals.
Richard
  •  9,356 9,356
Whilst it may well be possible to route the LPT output to 'print to file' (as is done with plotters) the code produced (say a different alphabetical letter for each pin pulse) would be massive for even a simple GCode routine.
(I did try something similar to this a while back to convert 'Master CNC' step and direction outputs to GCode before I realized the size of the files produced).
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
I suppose the answer must be yes, but as Tweakie says, with my system producing 60000 pulses per inch, I would end up with a lot of pulses.
A far better system would be a brain, of a short Macro which would produce the same result.
I'm thinking if  signals of "Direction" and "Steps" can be saved in ROM (read-only-memory), directly used for controlling stepper motors, then we can make many complex motion stuffs.(such as complex motion toys for kids, kids just need push on-button.)
  •  9,356 9,356
Hi Richard,
Would be nice wouldn't it - but as Jim has just implied saving 60k of pulses for every inch of movement for each axis you would need one big ROM.
I'd still like a testing, because ROM or flash memory is very cheap today , it's not easy to move  a computer (G-code/software)  anywhere we want.
Could somebody tell me how to do that testing?
Richard
