May 23, 2012, 09:13:10 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  SmoothStepper USB (Moderator: Warp9TD)
| | |-+  mpg on ss's lpt2
Pages: 1   Go Down
Print
Author Topic: mpg on ss's lpt2  (Read 966 times)
kdoney
Active Member
Offline Offline
View Profile
« on: February 24, 2009, 12:18:29 PM »
I can't get mach3 (latest version) to see an mpg
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=40&products_id=160
on ss's LPT2 port. I don't see ss's LPT2 port listed in my device manager. Is this the problem? I've used the given xml for using this mpg on the lpt2 port but I think going from ss is a problem. SS's LPT2 port is powered by SS's power, right?
By the way, everything works fine, jogging, encoder, speed, etc. without the mpg.
« Last Edit: February 24, 2009, 12:20:47 PM by kdoney » Logged
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: February 24, 2009, 03:46:56 PM »
Is the MPG set up in Ports and Pins , Encoder/MPGs page?
kdoney
Active Member
Offline Offline
View Profile
« Reply #2 on: February 24, 2009, 04:38:51 PM »
Yes, I used the template xml from the mpg manufacturer. I asked them if these are the settings to use with SS and they guessed it was right.
Active Member
Offline Offline
View Profile
« Reply #3 on: February 24, 2009, 06:27:30 PM »
They should be the same for either parallel port or SmoothStepper, one thing you may want to check is that in the SmoothStepper config you have pins 2-9 as Inputs checked for Port2
Pages: 1   Go Up
Print
Jump to:
