Hello
Guest
it is
June 09, 2026, 05:51:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
SmoothStepper USB
(Moderator:
Warp9TD
mpg on ss's lpt2
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mpg on ss's lpt2 (Read 12124 times)
kdoney
78
mpg on ss's lpt2
on:
February 24, 2009, 11:18:29 AM »
I can't get mach3 (latest version) to see an mpg
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=40&products_id=160
on ss's LPT2 port. I don't see ss's LPT2 port listed in my device manager. Is this the problem? I've used the given xml for using this mpg on the lpt2 port but I think going from ss is a problem. SS's LPT2 port is powered by SS's power, right?
By the way, everything works fine, jogging, encoder, speed, etc. without the mpg.
Last Edit: February 24, 2009, 11:20:47 AM by kdoney
Carnoustie, Scotland
Re: mpg on ss's lpt2
Reply #1 on:
February 24, 2009, 02:46:56 PM »
Is the MPG set up in Ports and Pins , Encoder/MPGs page?
kdoney
78
Reply #2 on:
February 24, 2009, 03:38:51 PM »
Yes, I used the template xml from the mpg manufacturer. I asked them if these are the settings to use with SS and they guessed it was right.
Reply #3 on:
February 24, 2009, 05:27:30 PM »
They should be the same for either parallel port or SmoothStepper, one thing you may want to check is that in the SmoothStepper config you have pins 2-9 as Inputs checked for Port2
Print
Pages:
1
Go Up
« previous
next »
