Hello
Guest
it is
June 10, 2026, 09:33:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach Screens
Button to call a menu item ?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Button to call a menu item ? (Read 28212 times)
Greolt
956
Re: Button to call a menu item ?
Reply #10 on:
February 21, 2009, 05:04:04 PM »
Scott
That one screws up the MDI for me like the first variant I posted did.
But adding the + seems to make it work OK,
SendKeys ("+%PV")
Greg
poppabear
2,235
Briceville, TN, USA
Reply #11 on:
February 21, 2009, 07:30:44 PM »
MDI??
I was sending it from inside a Button.........
scott
Greolt
956
Reply #12 on:
February 21, 2009, 07:54:26 PM »
Scott
Sorry there is more than one place this is getting discussed and I did not explain well.
When the button is used it calls the video OK but afterwards the MDI will not work.
What happens is the "Shift to over ride jogging" gets stuck on for some reason. Look on the tab flyout window.
Rod worked out that adding the + symbol (shift key) is a work around.
Greg
poppabear
2,235
Briceville, TN, USA
Reply #13 on:
February 22, 2009, 07:42:22 AM »
Where are you getting your list of "Symbols" for the various Keys ? Where does it list that the + symbol is the shift key and stuff??
scott
Greolt
956
Reply #14 on:
February 22, 2009, 02:50:02 PM »
http://www.developerfusion.com/article/57/sendkeys-command/
lelelodi
14
Reply #15 on:
May 21, 2009, 08:39:48 PM »
Hi, thanks for the suggestion, but i have a problem.
Somebody know why the SendKeys ("+%PV") work well with the normal button but doesn't work with image button ?
It's only my problem ? How i can fix it ?
Thank you
Lele
Greolt
956
Reply #16 on:
May 21, 2009, 09:32:29 PM »
Yes I found this also.
Interested to see if someone has an answer.
Greg
lelelodi
14
Reply #17 on:
May 22, 2009, 06:38:34 AM »
I've seen now that work with the double click but not with single...uhm....
Anybody know how i can fix this bug ?
Thank you
Lele
Print
Pages:
1
2
Go Up
« previous
next »
