February 13, 2012, 01:27:42 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  Finished Plugins for Download
| | | |-+  Elexol I/O 24 PlugIn
Pages: 1   Go Down
Print
Author Topic: Elexol I/O 24 PlugIn  (Read 2284 times)
smurph
Active Member
Offline Offline
View Profile
« on: February 19, 2009, 02:02:48 AM »
This is a PlugIn for the Elexol I/O 24 modules.  http://www.elexol.com
Up to 4 modules can be configured (Ethernet or USB), in any combination, for a total of 96 I/O pins.
The PlugIn utilizes a feature of the Elexol modules that eliminates polling.  So there is not much traffic in normal situations.  The USB modules are a breeze to setup.  Ethernet modules require a bit more knowledge, but there is setup software available from Elexol that makes it as painless as possible.
These are great little modules that can eliminate many cables from the Mach computer to the machine.  They can be used in conjunction with parallel port setups as the Mach port that each module uses is configurable.
If you like the idea of these modules, I would suggest getting their opto-isolated input boards and their relay output boards.  They will handle 24v systems this way and the risk of frying something is reduced.  Otherwise, the inputs and outputs are 5v TTL.
You can download the PlugIn here -->  http://www.smcomp.com/~smurph/Elexol/Elexol.m3p
And the documentation here --> http://www.smcomp.com/~smurph/Elexol/ElexolPlugIn.pdf
I hope you enjoy!
Steve
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #1 on: February 19, 2009, 08:38:06 AM »
    Thank you Sir for contributing such fine work!!  It is ALWAY great to have MORE IO!!! Looking forward to more of your work and comments.
Scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #2 on: January 15, 2010, 08:15:43 AM »
Why isn't this plugin on the Plugins Download page. No one probably even knows it's here??
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #3 on: January 15, 2010, 06:12:19 PM »
Thanks Steve, it looks very promising. Do you mind if we put it on the downloads page?
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
smurph
Active Member
Offline Offline
View Profile
« Reply #4 on: January 16, 2010, 01:44:52 AM »
No, not at all.  Put it up on the download page if you want.
The USB version seems to work best.  The UDP on the Ethernet version can get hung up occasionally on a crowded network.
Steve
csherrit
Active Member
Offline Offline
View Profile
« Reply #5 on: April 20, 2010, 02:34:24 PM »
can't get this plugin to load in Mach3 - Mach3 gives error dialog loading it when starting up .
Also,
 can anyone  provide some examples/ideas  for  use with Mach3 ?
thanks
Chaz
smurph
Active Member
Offline Offline
View Profile
« Reply #6 on: April 20, 2010, 03:59:24 PM »
Sounds like you don't have the FTDI drivers installed.  You need the one from their website and not the one that comes with Windows.
Pages: 1   Go Up
Print
Jump to:
